bags8000.reg problem
Discussion in 'Windows XP' started by savagcl, 2004/07/02.
  1. 2004/07/02
    savagcl Lifetime Subscription
    I copied this file from here but when i tried to merge(?) it (double click it) into the reg i got an error msg of:
    The specified file is not a registry script
    You can only import binary registry files from within the registry editor
    what did i do wrong?
    thanks,
    savagcl
  2. 2004/07/03
    Try again from here under Folder Views - Keep Settings. There is a downloadable Reg file.
    went to kelly's site (thanks, i had lost the site id).
    The "Apply to all folders" will not work automatically meaning you have to
    open each folder/drive, set it to what you want then it stays that way
    (sometimes).
    I didn't fins a downloadable file but i copied this:
    Windows Registry Editor Version 5.00
    [-HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\BagMRU]
    [-HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\Bags]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell]
    "BagMRU Size "=dword:00001f40
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
    "NoSaveSettings "=dword:00000000
    So now the question is: is the first line needed (Windows........) ?
    And is there a naming convention (besides .reg) for saving the above?
    Thanks for the help, PeteC,
    clif
    PS: I hate playing with the reg - know just enough to be dangerous!!
  5. 2004/07/03
    There is a link on the page I posted ....
    http://www.kellys-korner-xp.com/xp_tweaks.htm - line 2 which downloads bags8000.reg the contents of which are .....
    Simpler/safer to download that file rather than play about in the Registry :)
  6. 2004/07/03
    My bad, PeteC.
    I didn't right-click line 2, i just opened it......
    Its been a long day.. :)
    thanks, i'll do it again.
    savagcl
  7. 2004/07/03
    Yep, that works!
    Amazing what you don't know....
    thanks,
    savagcl
  8. 2004/07/04
    You're welcome :) Glad you got it sorted!
