Backup Problems
Discussion in 'Legacy Windows' started by Kevinwnz, 2003/12/28.
  1. 2003/12/28
    Kevinwnz
    Kevinwnz Inactive Thread Starter
    We are having problems getting the backup to run on win2k server
    We are using the native backup program in win2k
    and are backing up to folder on a hard disk
    The problem is windows task schedular is not running the backup up program, the backup works fine if you backup manually.
    any suggestions on what I can do.
  2. 2003/12/28
    Specify an admin account to run the task. It's one of the available settings when you create or modify a task.
