Back and Forward funtions not working for 6.2
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by zekezau, 2002/05/06.
  1. 2002/05/06
    zekezau
    zekezau Inactive Thread Starter
    Does anybody have solution to this problem? Back and foward buttion/fundion not working. Thanks.
  2. 2002/05/06
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum!
    Hello zekezau,
    Try this to solve your problem:
    Check in Edit | Preferences | Navigator | History , and make sure both numbers are greater than zero, and that the second number is high enough
    The defaulted is set to 50 and works fine, some use less than that with no problem.
    Let us know if this helps!
    Ramona :D
    zekezau
    Solution
    Tried the recommended solution, after reset both History value to 50 and restarted Netscape. The function is still not working.
  5. 2002/05/06
    zekezau
    Oops spoke too soon. Set values to 60 and it works. Thanks.
