AVG 8.0 causing bluescreen???
Discussion in 'Windows XP' started by bigtwenty, 2008/05/12.
  1. 2008/05/12
    bigtwenty
    bigtwenty Inactive Thread Starter
    Well, i dont know if they caught this in beta testing, but i think this is an AVG problem. Here is the history.
    2 machines, both dell, one older, one newer. Both had norton on them, running like two machines with Norton. Removed norton and installed AVG internet security 8.0 (paid version). Things were fine, until the user tried to vpn using a vpn client. Both Machines blue screen with the same error messages and pop out almost if not exactly identical .DMP files. I cannot fond anything via the web so i turn to you fellow BBS'rs.
    Microsoft (R) Windows Debugger Version 6.8.0004.0 X86
    Loading Dump File [c:\dmp\d4550\Mini051208-01.dmp]
    Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
    Executable search path is: c:\windows\i386
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp_sp2_gdr.070227-2254
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a620
    Debug session time: Mon May 12 11:11:57.046 2008 (GMT-4)
    System Uptime: 0 days 0:41:33.628
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 19, {20, 81fbea00, 81fbebc0, a380001}
    Unable to load image avgfwdx.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for avgfwdx.sys
    *** ERROR: Module load completed but symbols could not be loaded for avgfwdx.sys
    Unable to load image dne2000.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for dne2000.sys
    *** ERROR: Module load completed but symbols could not be loaded for dne2000.sys
    *** WARNING: Unable to verify timestamp for CVPNDRVA.sys
    *** ERROR: Module load completed but symbols could not be loaded for CVPNDRVA.sys
    *** WARNING: Unable to verify timestamp for e100b325.sys
    *** ERROR: Module load completed but symbols could not be loaded for e100b325.sys
    Probably caused by : avgfwdx.sys ( avgfwdx+26f1 )
    Followup: MachineOwner
    kd> !analyze -v;r;kv;lmtn;
    BAD_POOL_HEADER (19)
    The pool is already corrupt at the time of the current request.
    This may or may not be due to the caller.
    The internal pool links must be walked to figure out a possible cause of
    the problem, and then special pool applied to the suspect tags or the driver
    verifier to a suspect driver.
    Arguments:
    Arg1: 00000020, a pool block header size is corrupt.
    Arg2: 81fbea00, The pool entry we were looking for within the page.
    Arg3: 81fbebc0, The next pool entry.
    Arg4: 0a380001, (reserved)
    Debugging Details:
    BUGCHECK_STR: 0x19_20
    POOL_ADDRESS: 81fbea00
    CUSTOMER_CRASH_COUNT: 1
    PROCESS_NAME: Idle
    LAST_CONTROL_TRANSFER: from 8054b941 to 8053354e
    STACK_TEXT:
    8054fe60 8054b941 00000019 00000020 81fbea00 nt!KeBugCheckEx+0x1b
    8054feb0 f734260f 81fbea08 00000000 8054fee0 nt!ExFreePoolWithTag+0x2be
    8054fec0 f78b16f1 81fbea08 00000000 00000000 NDIS!NdisFreeMemory+0x3b
    8054fee0 f78b2bba 8213c828 82d41dac 82d41d98 avgfwdx+0x26f1
    8054ff00 f7364bd6 824f6c10 82284b6c 00000000 avgfwdx+0x3bba
    8054ff34 f6d193d1 82d41d98 82284b6c 821f11e8 NDIS!EthFilterDprIndicateReceive+0xe0
    8054ffb0 f6d140b7 82284b6c 822bd888 821f11e8 dne2000+0x153d1
    80550008 f3a50841 822bd888 824fa020 82facf08 dne2000+0x100b7
    80550060 f3a429e7 824fa020 82ea0bd8 81fe7758 CVPNDRVA+0xf841
    80550100 f7344ed0 f3a42ab5 824fa020 81fe7702 CVPNDRVA+0x19e7
    805501ac f7363c9f 82f1e5b8 8213c828 82a21568 NDIS!NdisAcquireSpinLock+0x11
    80550200 f6d3c78b 00ea80a0 80550220 00000001 NDIS!ethFilterDprIndicateReceivePacket+0x1c2
    80550368 f6d3c97b 01a21008 00000000 82ea2130 e100b325+0x978b
    80550394 f7359f09 00a21008 80559080 80558e20 e100b325+0x997b
    805503ac 804dbbd4 82a213e0 82a213cc 00000000 NDIS!ndisMDpcX+0x21
    805503c0 80558e20 ffdffc50 00000000 00000000 nt!KiRetireDpcList+0x46
    805503d0 804dbb4d 00000000 0000000e 00000000 nt!KiIdleThread0
    805503d4 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x26
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    avgfwdx+26f1
    f78b16f1 ?? ???
    SYMBOL_STACK_INDEX: 3
    SYMBOL_NAME: avgfwdx+26f1
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: avgfwdx
    IMAGE_NAME: avgfwdx.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 469c8d49
    FAILURE_BUCKET_ID: 0x19_20_avgfwdx+26f1
    eax=ffdff13c ebx=81fbea00 ecx=00000000 edx=000000f7 esi=81fbea00 edi=00000000
    eip=8053354e esp=8054fe48 ebp=8054fe60 iopl=0 nv up ei ng nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    nt!KeBugCheckEx+0x1b:
    8053354e 5d pop ebp
    8054fe60 8054b941 00000019 00000020 81fbea00 nt!KeBugCheckEx+0x1b (FPO: [Non-Fpo])
    8054feb0 f734260f 81fbea08 00000000 8054fee0 nt!ExFreePoolWithTag+0x2be (FPO: [Non-Fpo])
    8054fec0 f78b16f1 81fbea08 00000000 00000000 NDIS!NdisFreeMemory+0x3b (FPO: [Non-Fpo])
    8054ff34 f6d193d1 82d41d98 82284b6c 821f11e8 NDIS!EthFilterDprIndicateReceive+0xe0 (FPO: [Non-Fpo])
    805501ac f7363c9f 82f1e5b8 8213c828 82a21568 NDIS!NdisAcquireSpinLock+0x11 (FPO: [Non-Fpo])
    80550200 f6d3c78b 00ea80a0 80550220 00000001 NDIS!ethFilterDprIndicateReceivePacket+0x1c2 (FPO: [Non-Fpo])
    805503ac 804dbbd4 82a213e0 82a213cc 00000000 NDIS!ndisMDpcX+0x21 (FPO: [Non-Fpo])
    805503c0 80558e20 ffdffc50 00000000 00000000 nt!KiRetireDpcList+0x46 (FPO: [0,0,0])
    805503d4 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x26 (FPO: [0,0,0])
    start end module name
    804d7000 806eb500 nt ntoskrnl.exe Wed Feb 28 04:10:41 2007 (45E54711)
    806ec000 8070c380 hal halaacpi.dll Wed Aug 04 01:59:05 2004 (41107B29)
    bf000000 bf011580 dxg dxg.sys Wed Aug 04 02:00:51 2004 (41107B93)
    bf012000 bf41ec00 nv4_disp nv4_disp.dll Mon Oct 06 20:03:41 2003 (3F8202DD)
    bf800000 bf9c2800 win32k win32k.sys Wed Mar 19 05:46:46 2008 (47E0E106)
    bffa0000 bffe5c00 ATMFD ATMFD.DLL Wed Aug 04 03:56:56 2004 (411096C8)
    f1650000 f167a180 kmixer kmixer.sys Wed Jun 14 04:47:45 2006 (448FCD31)
    f2f70000 f2fb0280 HTTP HTTP.sys Thu Mar 16 20:33:09 2006 (441A03C5)
    f3051000 f3073080 RDPWD RDPWD.SYS Thu Jun 09 19:52:39 2005 (42A8D647)
    f320a000 f321e400 wdmaud wdmaud.sys Wed Jun 14 05:00:44 2006 (448FD03C)
    f3577000 f3585d80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
    f38ff000 f3950480 srv srv.sys Mon Aug 14 06:34:39 2006 (44E051BF)
    f3961000 f39636c0 mdmxsdk mdmxsdk.sys Wed Apr 09 16:48:53 2003 (3E948735)
    f3a41000 f3ac6000 CVPNDRVA CVPNDRVA.sys Thu Apr 20 10:33:39 2006 (44479BC3)
    f3aee000 f3afec00 avgtdix avgtdix.sys Wed Mar 12 07:46:16 2008 (47D7C288)
    f3b27000 f3b52d80 mrxdav mrxdav.sys Tue Dec 18 04:51:33 2007 (47679825)
    f45a7000 f45aa280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
    f463b000 f4644900 LMIRfsDriver LMIRfsDriver.sys Tue Mar 27 05:24:44 2007 (4608E2DC)
    f582c000 f5843480 dump_atapi dump_atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f5844000 f5859f00 avgldx86 avgldx86.sys Thu Jan 31 12:38:23 2008 (47A2078F)
    f585a000 f58c8a00 mrxsmb mrxsmb.sys Fri May 05 05:41:42 2006 (445B1DD6)
    f58fd000 f58ff900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
    f5919000 f5943a00 rdbss rdbss.sys Fri May 05 05:47:55 2006 (445B1F4B)
    f5944000 f5965d00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
    f5966000 f5986f00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
    f5987000 f59aec00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f59c3000 f59c5f80 mouhid mouhid.sys Fri Aug 17 16:47:57 2001 (3B7D82FD)
    f59cb000 f59cd580 hidusb hidusb.sys Fri Aug 17 17:02:16 2001 (3B7D8658)
    f59d7000 f5a2ee80 tcpip tcpip.sys Tue Oct 30 13:20:52 2007 (472767F4)
    f5a2f000 f5a41400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f6c2a000 f6c82e80 update update.sys Mon Apr 23 06:32:54 2007 (462C8B56)
    f6c83000 f6cb3100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
    f6cb4000 f6cc4e00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
    f6cc5000 f6cdb680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
    f6d00000 f6d02280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
    f6d04000 f6d1ee00 dne2000 dne2000.sys Wed Jun 29 22:42:24 2005 (42C35C10)
    f6d1f000 f6d32900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
    f6d33000 f6d55200 e100b325 e100b325.sys Thu Sep 19 17:59:48 2002 (3D8A48D4)
    f6d56000 f6d75b80 ctsfm2k ctsfm2k.sys Sun Sep 21 20:48:04 2003 (3F6E46C4)
    f6d76000 f6da18e0 ctoss2k ctoss2k.sys Sun Sep 21 20:47:37 2003 (3F6E46A9)
    f6da2000 f6dc5980 portcls portcls.sys Wed Aug 04 02:15:47 2004 (41107F13)
    f6dc6000 f6f0ab80 P16X P16X.sys Mon Sep 22 00:43:04 2003 (3F6E7DD8)
    f6f0b000 f6fb1300 HSF_CNXT HSF_CNXT.sys Mon Nov 17 08:58:00 2003 (3FB8D3E8)
    f6fb2000 f70b0800 HSF_DP HSF_DP.sys Mon Nov 17 08:56:13 2003 (3FB8D37D)
    f70b1000 f70d3680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f70d4000 f7107d00 HSFHWBS2 HSFHWBS2.sys Mon Nov 17 08:59:18 2003 (3FB8D436)
    f7108000 f712ae80 USBPORT USBPORT.SYS Wed Aug 04 02:08:34 2004 (41107D62)
    f712b000 f713e780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
    f713f000 f72a4be0 nv4_mini nv4_mini.sys Mon Oct 06 19:56:53 2003 (3F820145)
    f72b5000 f72b8c80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
    f72d1000 f72d3580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
    f72ed000 f72f0c80 serenum serenum.sys Wed Aug 04 01:59:06 2004 (41107B2A)
    f7326000 f7340580 Mup Mup.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f7341000 f736da80 NDIS NDIS.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f736e000 f73fa400 Ntfs Ntfs.sys Fri Feb 09 06:10:31 2007 (45CC56A7)
    f73fb000 f7411780 KSecDD KSecDD.sys Wed Aug 04 01:59:45 2004 (41107B51)
    f7412000 f7427360 PQV2i PQV2i.sys Thu Jul 29 05:33:06 2004 (4108C452)
    f7428000 f7439f00 sr sr.sys Wed Aug 04 02:06:22 2004 (41107CDE)
    f743a000 f7459780 fltMgr fltMgr.sys Mon Aug 21 05:14:57 2006 (44E97991)
    f745a000 f7471800 SCSIPORT SCSIPORT.SYS Wed Aug 04 01:59:39 2004 (41107B4B)
    f7472000 f7489480 atapi atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f748a000 f74af700 dmio dmio.sys Wed Aug 04 02:07:13 2004 (41107D11)
    f74b0000 f74ce880 ftdisk ftdisk.sys Fri Aug 17 16:52:41 2001 (3B7D8419)
    f74cf000 f74dfa80 pci pci.sys Wed Aug 04 02:07:45 2004 (41107D31)
    f74e0000 f750dd80 ACPI ACPI.sys Wed Aug 04 02:07:35 2004 (41107D27)
    f752f000 f7537c00 isapnp isapnp.sys Fri Aug 17 16:58:01 2001 (3B7D8559)
    f753f000 f7549500 MountMgr MountMgr.sys Wed Aug 04 01:58:29 2004 (41107B05)
    f754f000 f755bc80 VolSnap VolSnap.sys Wed Aug 04 02:00:14 2004 (41107B6E)
    f755f000 f7567e00 disk disk.sys Wed Aug 04 01:59:53 2004 (41107B59)
    f756f000 f757b200 CLASSPNP CLASSPNP.SYS Wed Aug 04 02:14:26 2004 (41107EC2)
    f757f000 f7589580 agp440 agp440.sys Wed Aug 04 02:07:40 2004 (41107D2C)
    f75af000 f75b7d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 02:08:18 2004 (41107D52)
    f75cf000 f75de900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
    f763f000 f7647d00 intelppm intelppm.sys Wed Aug 04 01:59:19 2004 (41107B37)
    f764f000 f765db80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
    f765f000 f766be00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f766f000 f767ed80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
    f767f000 f7689380 imapi imapi.sys Wed Aug 04 02:00:12 2004 (41107B6C)
    f768f000 f769b180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
    f769f000 f76ad080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
    f76af000 f76bb880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
    f76bf000 f76c9200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
    f76cf000 f76dad00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
    f76df000 f76e7900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
    f76ef000 f76f8f00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
    f771f000 f7728480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
    f772f000 f773d100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
    f775f000 f7767700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
    f776f000 f7777700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (41107C27)
    f777f000 f7787f20 PQIMount PQIMount.SYS Thu Jul 29 06:13:27 2004 (4108CDC7)
    f779f000 f77a7880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
    f77af000 f77b5200 PCIIDEX PCIIDEX.SYS Wed Aug 04 01:59:40 2004 (41107B4C)
    f77b7000 f77bb900 PartMgr PartMgr.sys Fri Aug 17 21:32:23 2001 (3B7DC5A7)
    f77bf000 f77c61c0 cercsr6 cercsr6.sys Wed Dec 08 18:31:10 2004 (41B78EBE)
    f77d7000 f77dba80 Msfs Msfs.SYS Wed Aug 04 02:00:37 2004 (41107B85)
    f77e7000 f77ee880 Npfs Npfs.SYS Wed Aug 04 02:00:38 2004 (41107B86)
    f77f7000 f77fc500 TDTCP TDTCP.SYS Wed Aug 04 01:58:52 2004 (41107B1C)
    f7807000 f780bc40 avgmfx86 avgmfx86.sys Thu Jan 10 12:05:15 2008 (4786504B)
    f781f000 f7825500 usbprint usbprint.sys Wed Aug 04 02:01:23 2004 (41107BB3)
    f782f000 f7835180 HIDPARSE HIDPARSE.SYS Wed Aug 04 02:08:15 2004 (41107D4F)
    f7837000 f783c000 usbuhci usbuhci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f783f000 f7845800 usbehci usbehci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f7857000 f785e580 Modem Modem.SYS Wed Aug 04 02:08:04 2004 (41107D44)
    f7867000 f786b500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
    f787f000 f7880000 fdc fdc.sys unavailable (00000000)
    f7887000 f788d000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f78a7000 f78ae000 GearAspiWDM GearAspiWDM.SYS Mon Aug 07 13:11:27 2006 (44D7743F)
    f78af000 f78b4800 avgfwdx avgfwdx.sys Tue Jul 17 05:35:05 2007 (469C8D49)
    f78cf000 f78d3880 TDI TDI.SYS Wed Aug 04 02:07:47 2004 (41107D33)
    f78df000 f78e3580 ptilink ptilink.sys Fri Aug 17 16:49:53 2001 (3B7D8371)
    f78ef000 f78f3080 raspti raspti.sys Fri Aug 17 16:55:32 2001 (3B7D84C4)
    f78f7000 f78fc020 wanatw4 wanatw4.sys Tue Jul 16 11:23:14 2002 (3D343A62)
    f78ff000 f7904a00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f7917000 f791c000 flpydisk flpydisk.sys Wed Aug 04 01:59:24 2004 (41107B3C)
    f792f000 f7934200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
    f793f000 f7942000 BOOTVID BOOTVID.dll Fri Aug 17 16:49:09 2001 (3B7D8345)
    f7a23000 f7a26f00 MODEMCSA MODEMCSA.sys Fri Aug 17 16:57:37 2001 (3B7D8541)
    f7a2b000 f7a2e240 OMCI OMCI.SYS Wed Aug 22 12:42:57 2001 (3B83E111)
    f7a2f000 f7a30b80 kdcom kdcom.dll Fri Aug 17 16:49:10 2001 (3B7D8346)
    f7a31000 f7a32100 WMILIB WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f7a33000 f7a34580 intelide intelide.sys Wed Aug 04 01:59:40 2004 (41107B4C)
    f7a35000 f7a36700 dmload dmload.sys Fri Aug 17 16:58:15 2001 (3B7D8567)
    f7a37000 f7a38680 avgrkx86 avgrkx86.sys Wed Dec 05 11:10:46 2007 (4756CD86)
    f7a41000 f7a42100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
    f7a43000 f7a44a80 ParVdm ParVdm.SYS Fri Aug 17 16:49:49 2001 (3B7D836D)
    f7a4f000 f7a50280 USBD USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
    f7a57000 f7a58780 RaInfo RaInfo.sys Mon Apr 09 19:37:22 2007 (461ACE32)
    f7a5b000 f7a5cf00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
    f7a5f000 f7a60080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
    f7a63000 f7a64080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
    f7a67000 f7a68080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
    f7a83000 f7a84100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f7af7000 f7af7d00 pciide pciide.sys Fri Aug 17 16:51:49 2001 (3B7D83E5)
    f7bd7000 f7bd7b80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
    f7c09000 f7c09d00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
    f7c1b000 f7c1bc00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
    Unloaded modules:
    f340f000 f3419000 ATWPKT2.SYS
    Checksum: 00000000
    f1650000 f167b000 kmixer.sys
    Checksum: 00000000
    f31bc000 f31e7000 kmixer.sys
    Checksum: 00000000
    f7bdb000 f7bdc000 drmkaud.sys
    Checksum: 00000000
    f5ab2000 f5abf000 DMusic.sys
    Checksum: 00000000
    f31e7000 f320a000 aec.sys
    Checksum: 00000000
    f3567000 f3575000 swmidi.sys
    Checksum: 00000000
    f7a59000 f7a5b000 splitter.sys
    Checksum: 00000000
    f7927000 f792c000 Cdaudio.SYS
    Checksum: 00000000
    f72e5000 f72e8000 Sfloppy.SYS
    Checksum: 00000000
    kd> lmvm avgfwdx
    f78af000 f78b4800 avgfwdx T (no symbols)
    Loaded symbol image file: avgfwdx.sys
    Image path: avgfwdx.sys
    Image name: avgfwdx.sys
    Timestamp: Tue Jul 17 05:35:05 2007 (469C8D49)
    CheckSum: 000107AE
    ImageSize: 00005800
    Translations: 0000.04b0 0000.04e0 0409.04b0 0409.04e0
    kd> lmvm avgfwdx
    CheckSum: 000107AE
    ImageSize: 00005800
  2. 2008/05/13
    Should consider looking on AVG's web site/support section....And look in AVG's security section and make sure VPN is enabled/not blocked.
