Autoplay Dialog Box
Discussion in 'Windows XP' started by Shortimer, 2006/03/10.
  1. 2006/03/10
    Shortimer
    Shortimer Inactive Thread Starter
    When I insert any disk into any of the CD/DVD rom drives on my computer the Windows XP Autoplay Dialog box pops up (as it should) but it is blank. There should be options like "Play Music ", "Open a Folder to view the Files ", etc. But I have NO actions to choose from, so I just close the box and move on.
    If I go to Open My Computer, right click on the CD drive, left click on Properties, and go to the AutoPlay tab, there are no Autoplay options listed, even when I scroll through the drop downs (Music CD, Blank CD, etc.). If I click on "Select an Action to Perform" (with the idea of hitting the "Restore Defaults" button) the "Restore Defaults" stays grayed out.
    This has been happening for a few weeks. I've uninstalled everything I think could have caused it, including my Norton Systemworks 2005, the antivirus part of which has been buggy for months.
    I'm running Windows XP SP2, and I'm fully updated. I use AVG antivirus, Adaware, and Ewido to take care of threats, so I think my system is pretty clean.
    How do I fix this? Everything else is seems to be working fine.
  2. 2006/03/10
    vbmark
    vbmark Inactive
    Shortimer
    That did it! Thanks for the tip!
