Audio device on High Audio definition
Discussion in 'PC Hardware' started by joedotm, 2007/07/17.
  1. 2007/07/17
    joedotm
    joedotm Inactive Thread Starter
    Hi,
    I built 3 PCs with the same specifications: Intel 945GC motherboard with the Intel CD drivers that comes with.
    I got the same failing error on the 3 while installing the Realtek audio driver.
    Pls advise.
    Thanx
  2. 2007/07/17
    Would help to post the detail of the error message.
    Have you checked out the Intel website for updated drivers - those on the CD may not be compatible - happens :)
    Install CD's sometimes fail to keep up with current hardware/software.
    Dennis L Inactive Alumni
    Not knowing what your MS updates status is, but about 4 / 6 months ago an MS update required to load/install new Realtek audio drivers... which I had to do on my computer. MS had an additional MS update you could install to make the problem go away, but I chose to just update the drivers.
  5. 2007/07/17
    http://www.intel.com/support/motherboards/desktop/chipline.htm
    I looked at the D945GCL, it only listed Sigmatel audio.
