ASUS A7V Motherboard Problem
Discussion in 'PC Hardware' started by blakston6286, 2005/04/01.
  1. 2005/04/01
    blakston6286 Lifetime Subscription
    blakston6286 Well-Known Member Thread Starter
    Hi,
    I have an ASUS A7V Motherboard....I bought it when it first came out because it was an A socket Motherboard and I wanted an AMD Athlon Processor based computer...
    When I ordered this Motherboard it was hailed as the best, newest for AMD processors..
    After years of everyone who bought them trying to find a fix for them it has been announced that the A7V is not compatable with AMD Processors and there is NO fix for them...
    My problem is,,,I have a really good AMD Athlon 900 Thunderbird Processor attached to this bogus Motherboard just going to waste.
    My questions are...
    1.) Has anyone had a good experience with a Motherboard that works extremely well with AMD Processors???
    2.) Is it possible to remove the 900 Thunderbird Processor from this crappy Motherboard and attach it to one that is compatable???
  2. 2005/04/01
    Bmoore1129
    Bmoore1129 Geek Member
    I have always used Gigabyte
    I have never had a problem.
    derfsch
    derfsch Well-Known Member
    I will second Bmoore's post. I've been using An AMD Athlon with a Gigbyte Technology board for about a year and a half with no problems. If your going to remove your AMD and install it on another board simply follow a good mounting practice to join them.
  5. 2005/04/01
    Bmoore1129...Thank you very much for the link
    I went to the site and found where to purchase a Motherboard...
    There was quite a few vendors listed....
    At least now I have lots of choices....
    Have you purchased from any one vendor continuoslly??? I am looking to buy from someone who has been in business for awhile and is a good bet to stay in business to be able to back up any warranty......
    derfsch......Thank you for the confirmation of the quality of the Gigabyte Motherboard....
    Is there a site I can go to that has the instructions for the proper way to remove and install my processor????
  6. 2005/04/01
    Hi,
    www.arcticsilver.com and go through the tutorials.
    When you are interested in a motherboard, go to the website and check the "CPU support" for that model (that it will run your 900 Thunderbird).
    BTW searching the Gigabyte website can be easier by using a Google search, eg., search for "GA-?????? CPU support ", although I think Gigabyte has recently updated their website and made it easier to find things.
  7. 2005/04/02
    Hi Matt,
    Thank you for the link and the information.....it is exactly what I needed to fill in the blanks with this process...
    Thank you Bmoore1129 and derfsch for the link and info about a better Motherboard.
    A. Blakston
