Windows Vista Arie's response made me think!
Discussion in 'Legacy Windows' started by alanrf, 2008/12/14.
  1. 2008/12/14
    alanrf
    alanrf Well-Known Member Thread Starter
    In the Getting Access Denied Messages When Accessing Folder thread I posted the following, (abridged for simplicity)
    For example:
    C:\Users\[username]\AppData\ was accessible with no issue.
    and
    c:\Users\[username]\Application Data\ was NOT accessible.
    Checking via the 'Properties' link led me to ... the 'Advanced Security Settings' page [where] there is a list current permissions ... showing, as the first entry 'Deny Everyone' ...
    Arie replied
    That is because \Users\[username]\Application Data\ is not a folder, it is a junction point that 're-directs' to \Users\[username]\AppData\.
    I don't know why people insist in accessing these 'folders' which aren't even showing by default (since they are 'hidden' folders).
    After a period of mature reflection I realise that Arie was quite correct and I thank him for his response. Having taken note, and before I hide those files, would it be a good idea to reintroduce those restrictive permissions?
    For the record I had changed the permissions in Application Data, Desktop, Documents, Favorites, Start Menu, Templates.
    by removing the line:
    [FONT= "Courier New"]Deny -- Everyone -- List folder / read data -- <not inherited> -- This folder only[/FONT]
  2. 2008/12/15
    Yes, I think you should revert to the default security settings.
    alanrf
    Thanks Arie.
    OK, I admit it! I should never have changed the [FONT= "Courier New"]Deny ... [/FONT]permissions in the first place, but, is there a simple way to reinstate them before I hide the files, or does it really matter that much?
    I did actually try hiding the files as an initial step but those files seem to be still available, presumably due the removal of the [FONT= "Courier New"]Deny ... [/FONT]line.
    Clearly, with the benefit of hindsight, of course, I should not have messed around. No harm appears to have been done, but, now , I just wonder .....
  5. 2008/12/16
    AFAIK there's no other way than to manually re-create them. Add the Everyone group & Deny for List folder / read data, Apply To should be set to This folder only.
