[Arctic Cooling P311 Bluetooth Headset not appearing in Win7 Sound options]
Discussion in 'PC Hardware' started by hawkeye6007, 2012/01/03.
  1. 2012/01/03
    hawkeye6007
    hawkeye6007 Inactive Thread Starter
    I was headset given an Arctic Cooling P311 Headset and am trying to get it to work in Windows 7 home premium.
    Although it appears to have installed correctly it it not appearing in the Sound options. If I check Devise Manager I find that the headset is shown.
    Having installed uninstalled and reinstalled at least 5 times I am about to throw the headset out! Incidentally, it works with my iPhone & a friends MacBook Pro so I know that the headset functions correctly.
    Can anyone help please?
  2. 2012/01/03
    Does your PC support BT?
    hawkeye6007
    arctic cooling P311 bluetooth headset not appearing in Win 7 sound options
    As I mentioned in my post it does appear in Devise Manager and when installed I get message that it has been installed. Since the only way to connect is BT I assume that BT radio is working.
  5. 2012/01/03
    What is the make and model of the PC?
  6. 2012/01/04
    Have you previously had any similar hardware/software installed?
    I suggest you uninstall any drivers/software for the headset in Control Panel -> Programs and Features. Also look for any similar, previously installed "hardware" and uninstall that.
    Have you previously had any similar hardware installed? Get rid of the software and start again.
