Application Running But Nothing
Discussion in 'Windows 7' started by joe645, 2014/01/17.
  1. 2014/01/17
    joe645
    joe645 Well-Known Member Thread Starter
    When I go to open an application from my desktop nothing happens. I go to Task Manager and it says it is running but I can't see anything. This happens with a few of the applications on the desktop but not with others.
  2. 2014/01/17
    James Martin
    James Martin Geek Member
    Can you name the applications?
    joe645
    Recycle, My Computer, Security (security files), Microsoft Office, and a couple of misc. folders do not open visually. Firefox, IE, Photoshop, others do.
  5. 2014/01/17
    James Martin
    I notice you have two monitors. Is it possible that the missing programs are showing up off the edge of the screen(s)?
    Maybe pressing Winkey + P will shed some light on your issue.
  6. 2014/01/17
    James Martin
  7. 2014/01/18
    While in Task Manager - if you end task and then try to open the apps - do they open?
