AOL and Shareaza question
Discussion in 'Other PC Software' started by Tarheeljcs, 2005/04/24.
  1. 2005/04/24
    Tarheeljcs
    Tarheeljcs Inactive Thread Starter
    My computer has a cable modem. I believe something has been set up wrong. I can never get a connection through AOL only AOL IM. Also, when using a P2P file sharing system, I can never get a connection. However, my IE works fine, and I can surf the net with ease. Some webmail sites do not work though. Any thoughts? I don't know if something is set up wrong with my cable modem? Please, any insight would be great, thanks!
  2. 2005/04/24
    Not likely to be the cable modem with those symptoms.
    Sounds like maybe a poorly set up firewall or something.
    It would really help to know your OS (including SP) and the specific cable modem.
