Any way to determine what process is "using" a given file?
Discussion in 'Windows XP' started by stelliger, 2010/07/03.
  1. 2010/07/03
    stelliger
    stelliger Well-Known Member Thread Starter
    A lot of times when I go to rename or delete a certain file, especially media files of a few hundred megs or more, I find I cannot do so for a LONG time, because I get the message "Cannot delete [file] because it is being used by another program ".
    Sometimes this goes on for over 5 minutes.
    I have tried disabling my resident virus scanner, when this happens, and yet I still get the error.
    There are other times, in the past, I've had this message persist until I reboot (various file types for various reasons).
    It would be nice to be able to tell what any given file is being accessed by.
  2. 2010/07/03
    Often times if you view/listen to the media files - that is enough to cause the problem. As you've seen - rebooting helps.
