Any free/shareware to help speed up comp??
Discussion in 'Legacy Windows' started by Kittie Cat, 2002/07/10.
  1. 2002/07/10
    Kittie Cat
    Kittie Cat Inactive Thread Starter
    I have cable internet and it seems like a darned dialup! My comp is running so s l o w !!! Is there anything I can do to speed it up? I always do a disk clean/defrag etc. but it isn't helping with the speed at all.
    Any help would be appreciated!! :mad:
  2. 2002/07/10
    Daizy
    Daizy Inactive
    Hi Kittie Cat
    Could you give us some system specs?
    Daizy
    Kittie Cat
    Hi Daizy, what do you need specifically? I'll try to find it for ya!
    nt
  5. 2002/07/10
    Daizy
    Daizy Inactive
    Hi Kittie Cat
    How be we start with:
    Brand
    Size
    Ram
    Hard Drive size?
    Daizy
  6. 2002/07/10
  7. 2002/07/10
    Kittie Cat
    Compaq 5204
    upgraded to:
    30 GB
    I can't find the memory size, although that was upgraded too. I'll keep looking...
  8. 2002/07/10
    Daizy
    Daizy Inactive
    Hi Kittie Cat
    Right click on My Computer....go to properties...then look under the performance tab.
    Daizy
  9. 2002/07/10
    Kittie Cat
    there is no performance tab! I could find this easily in win98 but not here! LOL!! There is: General; Network Identification; Hardware and User Profiles.
  10. 2002/07/10
    Kittie Cat
    196148 K for physical memory in the task manager, is that it?
  11. 2002/07/10
    Daizy
    Daizy Inactive
    :eek: Kittie cat....my ineptitude truly does have no bounds. (sigh)
    Sorry about that. That was my mistake not yours.
    Take a boo around the site Arie posted.......come back and let us know if you found anything useful..or need further help?
    Daizy
  12. 2002/07/10
    Daizy
    Daizy Inactive
    Ohhhhhh?
    And you might want to download and run Belarc . It's free, and small...and will tell you everything you want to know about your computer and more?
    Daizy
  13. 2002/07/10
    Kittie Cat
    Can I post here what it found? I think I have a LOT of **** on my computer and that is the problem....
  14. 2002/07/10
    Daizy
    Daizy Inactive
    Sure you can...........have at it Kitty Cat
  15. 2002/07/10
    Daizy
    Daizy Inactive
    Hi again Kittie Cat
    It would most probably behoove you to run Ad-aware . From the list that you PM'd me...I see you've got Gator installed. It's famous as a pain in the but and spyware. You've also Got Gain. Another nasty.
    Clean those up...and post back how it goes.
    Daizy
  16. 2002/07/10
    Kittie Cat
    Okay, got rid of Gain, but I cannot live w/o Gator!!! Is there something similar?
    I also just deleted a bunch of stuff but it's not helping speed much, dunno what is up with this!!!
    Thanks so much for helping out!!!
    :p
  17. 2002/07/11
    Daizy
    Daizy Inactive
    Yes, there's Roboform as an alternative.
    When you say you're deleting stuff? I hope you mean you're "uninstalling" programs properly through the control panel and add/remove.......rather than deleting them?
    Did you run adaware?
    Daizy
  18. 2002/07/11
    Hex92
    Hex92 Inactive
    Check out DSLReports. Their tools section allows you to test your connection speed and make suggestions as to what you can tweak to maximize your settings.
    DSLreports
  19. 2002/07/11
    Kittie Cat
    Well.......... Most I used the unistall feature but
    some didn't have one so I just deleted the whole file. GREAT. Now what did I do? LOL!! Can I fix that or is that gonna mess everything up? I'm running AdAware right now and will part with my Gator if I MUST. I can try that other one you recommended but thing is, I don't remember all my passwords!! LOL!!
    *sigh*
    We'll see what happens with this AdAware thing...
    :confused:
