Active Antivirus System Pro, Blocking programs
Discussion in 'Malware and Virus Removal Archive' started by amanda, 2009/11/26.
  1. 2009/11/26
    amanda
    amanda Inactive Thread Starter
    [Active] Antivirus System Pro, Blocking programs
    Hello,
    My mother recently got this Antivirus System Pro malware/virus on both her netbook and just now her laptop. I messed up her netbook by going into safeboot, have yet to get to fixing it /reinstalling windows. Anyways, now she has it on her laptop (with alot of data she needs not backed up yet).
    I have read a few resources online, uninstalls, etc and have tried to run rKill from bleepingcomputer, ComboFix, MalwareBytes, Task Manager, all of them are blocked I cannot access any programs other than IE/FF.
    Is there a way I can fix this? I cannot run the prereq program that you talk about in the rules for posting because it blocks everything.
    Thank you
    Amanda
  2. 2009/11/26
    Please download ComboFix from HERE to your Desktop.
    I renamed the file for a reason.
    If normal mode doesn't work, try to run it from Safe Mode.
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    2. Close any open browsers.
      • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
      • Double click on combofix.exe & follow the prompts.
      • When finished, it will produce a report for you.
      • Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
      Download HijackThis:
      http://www.trendsecure.com/portal/en-US/tools/security_tools/hijackthis/download
      by clicking on Download HijackThis Installer
      Install, and run it.
      Post HijackTHis log.
      Do NOT attempt to fix anything!
      NOTE. If you're using Vista, right click on HijackThis, and click Run as Administrator
