anticipated Motherboard upgrade problems?
Discussion in 'Windows XP' started by Aku, 2004/12/21.
  1. 2004/12/21
    Aku
    Aku Inactive Thread Starter
    I am going to be installing a nwe motherboard and processor, removing my wired, and wireless, NIC's, in favor of my motherboards onboard LAN. Due to Windows Product Activation, I am a little worried about things. Will everything be ok? This is going to be a massive hardware change, and I just want it to work.
    Also...I lost the discs that came with my motherboard, but I downloaded drivers from ASUS. If I have these on my hard drive and I replace the mobo, can I just run the EXE and everything will be ok? or will it refuse to boot?
    I'm going from a P3 to P4 based Celeron.
    Aku,
  2. 2004/12/21
    Top Dog
    Top Dog Inactive
    Upgrade MB with Exist XP drive
    Yes, I'm pretty sure you will end up calling M$ to reactivate, but shouldnt be a problem.
    If you wish to keep your programs and files, I suggest you do solution 2 at -->
    http://www.windowsreinstall.com/install/other/motherboard/winxp.htm
    and look at the link for win2k for more detail.
    I've done this several times without a hitch.
    Good Luck
    Top Dog
