Another shortcut for Ctrl-Alt-Del
Discussion in 'Windows XP' started by joedotm, 2007/07/07.
  1. 2007/07/07
    joedotm
    joedotm Inactive Thread Starter
    Hi,
    My delete key is out of service.
    Can create another shortcut for Ctrl-Alt-Del?
    Thanx
  2. 2007/07/07
    Ctrl+Shift+Esc will get you to Task Manager
    sparrow
    sparrow Inactive
    Rt-clk in a blank area on the taskbar.
  5. 2007/07/09
    hawkeye
    hawkeye Inactive
    Control Alt Delete Shortcut
    go to C:\windows\system 32|taskmgr.exe and make a shortcut
    drag it to your desktop or copy and paste on your desktop
    now when you click on the icon task manager will come up
  6. 2007/07/09
    joedotm
    Hello and thanx a lot; your replies did the job. Thanx again.
  7. 2007/07/09
    hawkeye
    hawkeye Inactive
    you are welcome, pleased it helped.
