Another IRQL_Not_Less_or_equal error (with minidump file)
Discussion in 'Windows XP' started by Gustave, 2006/08/04.
  1. 2006/08/04
    Gustave
    Gustave Inactive Thread Starter
    Hi,
    I just built a new computer, and I'm having a lot of problems with BSODs. I use a AMD Sempron 754 3000+ on a Biostar NF4 board. I've run memtest86 on the RAM (I have 1 gig of it) and found no problems. This is what I get for minidumps:
    * Bugcheck Analysis *
    BugCheck 100000D1, {0, 2, 8, 0}
    Probably caused by : ntkrnlpa.exe ( nt!IopTimerDispatch+42 )
    Followup: MachineOwner
    kd> !analyze -v
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: 00000000, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000008, value 0 = read operation, 1 = write operation
    Arg4: 00000000, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: 00000000
    CURRENT_IRQL: 2
    FAULTING_IP:
    +0
    00000000 ?? ???
    PROCESS_NAME: Idle
    CUSTOMER_CRASH_COUNT: 12
    DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
    BUGCHECK_STR: 0xD1
    LAST_CONTROL_TRANSFER: from 804f341c to 00000000
    STACK_TEXT:
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    80548cc4 804f341c 00000000 00000400 804f33da 0x0
    80548ce4 804ff234 80550a40 00000000 5678c590 nt!IopTimerDispatch+0x42
    80548e00 804ff34b 80551b80 80551920 ffdff000 nt!KiTimerListExpire+0x122
    80548e2c 80540d5d 80551f80 00000000 00009acc nt!KiTimerExpiration+0xaf
    80548e40 80551920 ffdffc50 00000000 00000000 nt!KiRetireDpcList+0x46
    80548e50 80540cd6 00000000 0000000e 00000000 nt!KiIdleThread0
    80548e54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x26
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    804f341c 4b dec ebx
    SYMBOL_STACK_INDEX: 1
    SYMBOL_NAME: nt!IopTimerDispatch+42
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlpa.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 42250a1d
    FAILURE_BUCKET_ID: 0xD1_W_nt!IopTimerDispatch+42
  2. 2006/08/04
    Gustave
    Sometimes it's at a different bugcheck:
    BugCheck 1000000A, {fffffffe, 2, 0, 804f340c}
    Probably caused by : ntkrnlpa.exe ( nt!IopTimerDispatch+32 )
    kd> !analyze -v
    IRQL_NOT_LESS_OR_EQUAL (a)
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: fffffffe, memory referenced
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: 804f340c, address which referenced memory
    Debugging Details:
    READ_ADDRESS: fffffffe
    CURRENT_IRQL: 2
    FAULTING_IP:
    804f340c 66837efe00 cmp word ptr [esi-2],0
    CUSTOMER_CRASH_COUNT: 11
    BUGCHECK_STR: 0xA
    PROCESS_NAME: Idle
    LAST_CONTROL_TRANSFER: from 804ff234 to 804f340c
    STACK_TEXT:
    80548ce4 804ff234 80550a40 00000000 c8e3e15c nt!IopTimerDispatch+0x32
    80548e2c 80540d5d 80551f80 00000000 000037ca nt!KiTimerExpiration+0xaf
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: nt!IopTimerDispatch+32
    MODULE_NAME: nt
    FAILURE_BUCKET_ID: 0xA_nt!IopTimerDispatch+32
    Follow these instructions to post a Dump Data Log.
    Although its doubtful we can be of much help here, as there are no experts at reading those dumps :(
    Gustave
    Well I'll try this anyway.
    BugCheck 100000D1, {1c6b040, 2, 8, 1c6b040}
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    Arguments:
    Arg1: 01c6b040, memory referenced
    Arg4: 01c6b040, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: 01c6b040
    CURRENT_IRQL: 2
    FAULTING_IP:
    +1c6b040
    01c6b040 ?? ???
    PROCESS_NAME: Idle
    BUGCHECK_STR: 0xD1
    LAST_CONTROL_TRANSFER: from 804f341c to 01c6b040
    STACK_TEXT:
    80548cc4 804f341c 01c6b044 c2d815a6 804f33da 0x1c6b040
    80548ce4 804ff234 80550a40 00000000 f6cfcd6c nt!IopTimerDispatch+0x42
    80548e2c 80540d5d 80551f80 00000000 00233472 nt!KiTimerExpiration+0xaf
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    804f341c 4b dec ebx
    MODULE_NAME: nt
    eax=00000002 ebx=0000000a ecx=00000041 edx=00000004 esi=8226a40c edi=80550a60
    eip=01c6b040 esp=80548cc8 ebp=80548ce4 iopl=0 nv up ei pl nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206
    01c6b040 ?? ???
    80548ce4 804ff234 80550a40 00000000 f6cfcd6c nt!IopTimerDispatch+0x42 (FPO: [Non-Fpo])
    80548e00 804ff34b 80551b80 80551920 ffdff000 nt!KiTimerListExpire+0x122 (FPO: [Non-Fpo])
    80548e2c 80540d5d 80551f80 00000000 00233472 nt!KiTimerExpiration+0xaf (FPO: [Non-Fpo])
    80548e40 80551920 ffdffc50 00000000 00000000 nt!KiRetireDpcList+0x46 (FPO: [0,0,0])
    80548e54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x26 (FPO: [0,0,0])
    start end module name
    804d7000 806cd280 nt ntkrnlpa.exe Tue Mar 01 19:34:37 2005 (42250A1D)
    806ce000 806ee380 hal halaacpi.dll Wed Aug 04 01:59:05 2004 (41107B29)
    afa2b000 afa4e000 Fastfat Fastfat.SYS Wed Aug 04 02:14:15 2004 (41107EB7)
    b0b15000 b0b55280 HTTP HTTP.sys Thu Mar 16 19:33:09 2006 (441A03C5)
    b0d5e000 b0daf400 srv srv.sys Fri Apr 21 02:12:25 2006 (444877C9)
    b0e00000 b0e2c400 mrxdav mrxdav.sys Wed Aug 04 02:00:49 2004 (41107B91)
    b1012000 b1026400 wdmaud wdmaud.sys Wed Aug 04 02:15:03 2004 (41107EE7)
    b110f000 b111dd80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
    b161b000 b161e280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
    bf800000 bf9c1180 win32k win32k.sys Wed Oct 05 20:05:44 2005 (43446A58)
    bf9c2000 bf9d3580 dxg dxg.sys Wed Aug 04 02:00:51 2004 (41107B93)
    bf9d4000 bfd9ce00 nv4_disp nv4_disp.dll Thu Mar 09 19:31:16 2006 (4410C8D4)
    bffa0000 bffe5c00 ATMFD ATMFD.DLL Wed Aug 04 03:56:56 2004 (411096C8)
    f0710000 f0727480 dump_atapi dump_atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f0728000 f0738280 Udfs Udfs.SYS Wed Aug 04 02:00:27 2004 (41107B7B)
    f0761000 f0781f00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
    f0782000 f07f0a00 mrxsmb mrxsmb.sys Fri May 05 05:41:42 2006 (445B1DD6)
    f07f1000 f081ba00 rdbss rdbss.sys Fri May 05 05:47:55 2006 (445B1F4B)
    f081c000 f083dd00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
    f083e000 f0865c00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f0866000 f08bdd80 tcpip tcpip.sys Thu Apr 20 07:51:47 2006 (444775D3)
    f08be000 f08d0400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f2a4c000 f2a5c480 nvarm nvarm.sys Wed Apr 13 15:34:21 2005 (425D743D)
    f2a5d000 f2b42000 nvmcp nvmcp.sys Wed Apr 13 15:34:21 2005 (425D743D)
    f2b42000 f2b65980 portcls portcls.sys Wed Aug 04 02:15:47 2004 (41107F13)
    f2b66000 f2bcb300 nvapu nvapu.sys Wed Apr 13 15:34:01 2005 (425D7429)
    f2bf9000 f2c2c200 update update.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f2c2d000 f2c5d100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
    f360b000 f361be00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
    f361c000 f3632680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
    f36bd000 f36d0900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
    f36d1000 f36e4780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
    f36e5000 f3a60340 nv4_mini nv4_mini.sys Thu Mar 09 19:40:42 2006 (4410CB0A)
    f3ae4000 f3b16d80 NVSNPU NVSNPU.SYS Wed Apr 06 06:22:01 2005 (4253B849)
    f3b17000 f3b56f00 NVNRM NVNRM.SYS Wed Apr 06 06:22:11 2005 (4253B853)
    f3b57000 f3b79680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f3b7a000 f3b9ce80 USBPORT USBPORT.SYS Wed Aug 04 02:08:34 2004 (41107D62)
    f3e0e000 f3e0eb80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
    f3e4a000 f3e4ac00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
    f433b000 f433d580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
    f433f000 f4342c80 serenum serenum.sys Wed Aug 04 01:59:06 2004 (41107B2A)
    f43a1000 f43a4280 nvnetbus nvnetbus.sys Wed Apr 06 06:22:28 2005 (4253B864)
    f516a000 f5172900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
    f517a000 f5185d00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
    f518a000 f5194200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
    f519a000 f51a6880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
    f51aa000 f51b6e00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f51ba000 f51c9d80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
    f51da000 f51e8080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
    f8186000 f8188900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
    f81ce000 f81e8580 Mup Mup.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f81e9000 f8215a80 NDIS NDIS.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f8216000 f82a2480 Ntfs Ntfs.sys Wed Aug 04 02:15:06 2004 (41107EEA)
    f82a3000 f82b9780 KSecDD KSecDD.sys Wed Aug 04 01:59:45 2004 (41107B51)
    f82ba000 f82cbf00 sr sr.sys Wed Aug 04 02:06:22 2004 (41107CDE)
    f82cc000 f82ea780 fltMgr fltMgr.sys Wed Aug 04 02:01:17 2004 (41107BAD)
    f82eb000 f8301d80 nvata nvata.sys Thu Aug 18 20:52:05 2005 (43052D35)
    f8302000 f8319480 atapi atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f831a000 f833f700 dmio dmio.sys Wed Aug 04 02:07:13 2004 (41107D11)
    f8340000 f835e880 ftdisk ftdisk.sys Fri Aug 17 16:52:41 2001 (3B7D8419)
    f835f000 f836fa80 pci pci.sys Wed Aug 04 02:07:45 2004 (41107D31)
    f8370000 f839dd80 ACPI ACPI.sys Wed Aug 04 02:07:35 2004 (41107D27)
    f849f000 f84a7c00 isapnp isapnp.sys Fri Aug 17 16:58:01 2001 (3B7D8559)
    f84af000 f84b9500 MountMgr MountMgr.sys Wed Aug 04 01:58:29 2004 (41107B05)
    f84bf000 f84cbc80 VolSnap VolSnap.sys Wed Aug 04 02:00:14 2004 (41107B6E)
    f84cf000 f84d7e00 disk disk.sys Wed Aug 04 01:59:53 2004 (41107B59)
    f84df000 f84eb200 CLASSPNP CLASSPNP.SYS Wed Aug 04 02:14:26 2004 (41107EC2)
    f850f000 f8518f00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
    f852f000 f853db80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
    f853f000 f8548480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
    f857f000 f8587700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (41107C27)
    f859f000 f85ad100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
    f85af000 f85be900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
    f85bf000 f85cd000 AmdK8 AmdK8.sys Mon Jun 19 02:37:31 2006 (4496462B)
    f85ff000 f8607300 NVENETFD NVENETFD.sys Wed Apr 06 06:22:26 2005 (4253B862)
    f861f000 f8627880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
    f864f000 f8657700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
    f86bf000 f86cc080 nvax nvax.sys Wed Apr 13 15:32:41 2005 (425D73D9)
    f86ff000 f8709380 imapi imapi.sys Wed Aug 04 02:00:12 2004 (41107B6C)
    f870f000 f871b180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
    f871f000 f8725200 PCIIDEX PCIIDEX.SYS Wed Aug 04 01:59:40 2004 (41107B4C)
    f8727000 f872b900 PartMgr PartMgr.sys Fri Aug 17 21:32:23 2001 (3B7DC5A7)
    f8747000 f874ca00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f874f000 f8755000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f8757000 f875b880 TDI TDI.SYS Wed Aug 04 02:07:47 2004 (41107D33)
    f876f000 f8773580 ptilink ptilink.sys Fri Aug 17 16:49:53 2001 (3B7D8371)
    f8777000 f877b280 usbohci usbohci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f877f000 f8783080 raspti raspti.sys Fri Aug 17 16:55:32 2001 (3B7D84C4)
    f87ef000 f87f3500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
    f8807000 f880e880 Npfs Npfs.SYS Wed Aug 04 02:00:38 2004 (41107B86)
    f882f000 f8834200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
    f8897000 f889ba80 Msfs Msfs.SYS Wed Aug 04 02:00:37 2004 (41107B85)
    f889f000 f88a5800 usbehci usbehci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f88a7000 f88ae000 GEARAspiWDM GEARAspiWDM.sys Wed Feb 02 00:19:49 2005 (420062F5)
    f88af000 f88b2000 BOOTVID BOOTVID.dll Fri Aug 17 16:49:09 2001 (3B7D8345)
    f8937000 f8939280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
    f8973000 f8976580 BIOS BIOS.sys Wed Mar 16 01:23:52 2005 (4237D0F8)
    f899b000 f899ec80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
    f899f000 f89a0b80 kdcom kdcom.dll Fri Aug 17 16:49:10 2001 (3B7D8346)
    f89a1000 f89a2100 WMILIB WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f89a3000 f89a4700 dmload dmload.sys Fri Aug 17 16:58:15 2001 (3B7D8567)
    f89c1000 f89c2100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f89c9000 f89ca100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
    f89cf000 f89d0280 USBD USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
    f89d7000 f89d8a80 ParVdm ParVdm.SYS Fri Aug 17 16:49:49 2001 (3B7D836D)
    f89f5000 f89f6f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
    f89f7000 f89f8080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
    f89f9000 f89fa080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
    f89fb000 f89fc080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
    f8a67000 f8a67d00 pciide pciide.sys Fri Aug 17 16:51:49 2001 (3B7D83E5)
    f8af5000 f8af5d00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
    Unloaded modules:
    ae52a000 ae554000 kmixer.sys
    Checksum: 00000000
    ae92c000 ae956000 kmixer.sys
    Checksum: 00000000
    f87bf000 f87c6000 USBSTOR.SYS
    Checksum: 00000000
    b03f3000 b041d000 kmixer.sys
    Checksum: 00000000
    b0f25000 b0f4f000 kmixer.sys
    Checksum: 00000000
    f8b50000 f8b51000 drmkaud.sys
    Checksum: 00000000
    b10df000 b10ec000 DMusic.sys
    Checksum: 00000000
    b10ef000 b10fd000 swmidi.sys
    Checksum: 00000000
    b0fef000 b1012000 aec.sys
    Checksum: 00000000
    f89b1000 f89b3000 splitter.sys
    Checksum: 00000000
    f858f000 f8598000 processr.sys
    Checksum: 00000000
    f881f000 f8824000 Cdaudio.SYS
    Checksum: 00000000
    f8943000 f8946000 Sfloppy.SYS
    Checksum: 00000000
    f87d7000 f87dc000 Flpydisk.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  6. 2006/08/06
    Start by testing your memory. Run Memtest86 or Windows Memory Diagnostic.
    If you have more dumps, post another 2 here (you can stop at the Unloaded modules section).
