another FAN
Discussion in 'PC Hardware' started by dodong1, 2011/01/17.
  1. 2011/01/17
    dodong1
    dodong1 Inactive Thread Starter
    i'm trying to use a fan (still runs) from busted power supply. It's a 12 v,0.15 amp fan, i'm planning to use it coz it still runs maybe as an extra cooling device. i'v got a 500 watt power supply and an ASrock ALiveNF7G-HD720p motherboard
  2. 2011/01/17
    Hi dodong1, just make sure you mount it the right way round as it will PULL or PUSH the air. You should be able to power it from one of the 4 pin connector plugs and you can buy male/female connector leads from Computer shops to hook up with. Cheers Neil.
    dodong1
    thank you for the reply. would it be possible if i just connect it to the four pin connector plug by just connecting the black and red wire (fan wires) to the four pin connector plug which has 2 blacks, 1 red and a yellow wire just to save some cash? and where would i connect it (corresponding wires)? by the way how would you suggest i mount it, going in or out (air). i'm planning to mount it in my CRT monitor, got no Air con yet. hehe
