Alternate port forwarding
Discussion in 'Networking (Hardware & Software)' started by eannatone, 2005/10/11.
  1. 2005/10/11
    eannatone
    eannatone Inactive Thread Starter
    I have a linksys befvp41 router. I have a PC behind the router that needs to use port 25 to send e-mail (can't be changed) but our ISP blocks port 25 so it needs to be changed to port 587 on the way out of the router. Does UpnP take care of this or port triggering?
  2. 2005/10/11
    oshwyn5
    oshwyn5 Inactive
    Why can't you change the PC to send using port 587?
    Just specify that as the smtp port in the client .
    eannatone
    as stated in my original posting the 25 can not be changed, the application does not let you change it. Taskrunner 2.2
  5. 2005/10/12
    eannatone
    any other suggestions.
    I tried port triggering and UPNP again and still a no go.
    is this even possible
    can a windows port be chnaged on its way out with some sort of app. preferably free
  6. 2005/10/12
    #5
  7. 2005/10/13
    eannatone
    thanks newt i did.
    I am waiting for response.
    However this is still something i would like to know how to do.
    if it is possible to change the outgoing ports.
  8. 2005/10/13
    Dennis L Inactive Alumni
    Read this somewhere, can't remember if this works on SMTP server, but you can try.
    Go to Taskrunner settings ...
    email tab
    try the following settings for SMTP Server
    mail.myserver.com 587
    -(or)-
    mail.myserver.com:587
    substitute the correct ISP domain name for myserver.com
    The above is a port over-ride / redirect ... might work :confused:
  9. 2005/10/13
    eannatone
    thanks dennis i tried that and it did not work.
    However i e-mailed the author of the app and he will allow for this port change in his next release, hopefully tonite.
  10. 2005/10/13
    Wow - very accommodating programmer. Let us know when you have it up and running.
  11. 2005/10/14
    ericiga
    ericiga Inactive
    You might also contact your ISP. When I switched to DSL SBC was blocking port 25, but they offered an opt out option so that you could use port 25. It only took about a day before I could start sending messages from my server.
    Just my 2 cents.
    Eric
  12. 2005/10/14
    eannatone
    i am on SBC like flies on you know what
