Resolved Alt Key problem
Discussion in 'PC Hardware' started by ozpy, 2010/10/06.
  1. 2010/10/06
    ozpy
    ozpy Inactive Thread Starter
    [FONT= "Microsoft Sans Serif"]The fn key requires holding down for keyboard to type normally on US keyboard on a Benq Laptop running Vista:(
    Thank you, trevor[/FONT]
    ozpy,
  2. 2010/10/06
    markmadras
    markmadras Banned
    So, what happens when you don't hold it down?
    Check the keyboard settings for keyboard layout.
    It may help to tell us your OS.
    ozpy
    It may help to tell us your OS. "
    Responses: When the alt Key is not depressed only the alt characters appear'
    No mention of Layout of keyboard in Control Panel, Keyboard standard PS/2
    OS is Vista
    SORRY It is the "fn" function key that is the problem
    ozpy,
    goddez1
    goddez1 Inactive
    I am going to assume this was solved by using one of the key combinations provided by link that will work for release or setting FN key lock/unlock/invert settings.
    Several to try as the right combination may be comp/specific.
    See for possibles:
    http://en.kioskea.net/forum/affich-16321-the-fn-key
