Resolved AirLink101 AWLL6075 Wireless N Adapter
Discussion in 'Networking (Hardware & Software)' started by AceH, 2011/02/15.
  1. 2011/02/15
    AceH
    AceH Inactive Thread Starter
    Running WinXP SP3 on a laptop computer.
    I correctly installed an AirLink101 AWLL6075 Wirless N USB Adapter but I can't get it to work. There is a green light on the USB Adapter which is blinking so I assume that's working alright. There's a AirLink Monitor in the system tray which is supposed to show my wireless network connection but I can't seem to enable the Monitor thus it can't find any wireless networks. When you open the AirLink wireless monitor, there is a box in front of "Disable Monitor" which is always checked but when I uncheck the box a few seconds later it automatically checks itself again.
    This is my second Wireless N USB Adapter because of this problem I returned the first one thinking it was defective but apparently there is some other issue going on. I have disabled my built-in wireless connection and tried everything I know but I can't get it to work. Any help would be appreciated.
    P.S. I downloaded and installed the latest drivers and software from the AirLink website.
    AceH,
  2. 2011/02/16
    AceH
    Problem Solved! I was instructed by AirLink to install the drivers without installing the software and that worked.
    AceH,
