Adobe problems
Discussion in 'Other PC Software' started by F4Driver, 2009/07/12.
  1. 2009/07/12
    F4Driver
    F4Driver Inactive Thread Starter
    Computer all of a sudden started to rty to open most all applications with Adobe.Adobe icon was also behind most icons on my desk top.
    Deleted adobe and cured the problem, but, when I downloaded adobe 9.1 to replace it, same problem. Downloaded older version, same problem. Help!
  2. 2009/07/12
    Hi F4Driver. Welcome to Windowsbbs! :)
    Try downloading and running the .EXE file association fix from here.
    F4Driver
    Evan, thanks, but is this a fix for XP? I'm running Vista.
  5. 2009/07/13
