Resolved Adobe Flash Player does not load
Discussion in 'Other PC Software' started by msbooch, 2009/06/07.
  1. 2009/06/07
    msbooch
    msbooch Inactive Thread Starter
    Suddenly I am getting messages to download the Adobe Flash Player which I never had problems before on these sites before. I gather it is an upgrade. Even so, when I click on the Adobe icon, it gives me the ActiveX yellow bar and I click on to install. Gives me the install block but nothing happens.
    1. Is there some site I can try to install the latest Adobe Flash Player and know that it has been installed?
    2. Where does it install? I assumed it was put in the Adobe folder but no way. So where does it load so I can check to see if it installed?
    Using WindowsXP with IE.
  2. 2009/06/07
    Hi msbooch. Also, if Petes suggestion doesn't work then try downloading and installing flash player from here.
  5. 2009/06/08
    msbooch
    Thanks for the help. Pete, I did as you suggested in your message and all is o.k. now.
    Thanks again.
  6. 2009/06/08
    Glad you were able to get your issue resolved. :)
  7. 2009/06/09
    You're welcome :)
    It is important to uninstall previous versions of Flash before updating to a later version, otherwise problems may occur.
