add or remove [programs problem]
Discussion in 'Windows XP' started by savagcl, 2005/01/16.
  1. 2005/01/16
    savagcl Lifetime Subscription
    I tried to remove a program from the CP using Add or Remove. Got a msg saying that the file couldnt be found.
    Fairly common question but a search didnt turn any specifics.
    I thought TweakUI could remove the entry from the Add or Remove list but
    dont seem to be able to find it.
    How can i remove the entry in the add/remove list?
    thanks,
    savagcl
    (I know i'll hate myself when i find the answer)
  2. 2005/01/16
    runta08
    runta08 Inactive
    Have a look in your registry :
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
    Then if you find what your looking for, just delete it (be careful).
    Please follow Posting Rules (#3 - Meaningful Subject) when posting.
    I have adjusted your subject.
  5. 2005/01/16
    Admin,
    sorry, will try to be a little more descriptive in the future.
    savagcl
  6. 2005/01/16
    runta08,
    thank you, that did it.
    Amazing what you can do, when you know how to do it. :)
    savagcl
  7. 2005/01/16
    surferdude2
    surferdude2 Inactive
    For those who don't like editing the Registry manually, RegCleaner by Jouni Vuorio edits that menu nicely and even makes a backup in case you goof. It does many other things well also. It's free but getting harder to find every passing day.
  8. 2005/01/16
    surferdude2,
    Thanks, just what i was looking for (in another msg).
    Was looking for something to get rid of old DLL's and it looks like this
    just might do it.
    appreciate it,
    savagcl
