Adapter state not found in registry WiFi stopped working after updating to
Discussion in 'Windows XP' started by StratWiz, 2010/09/18.
  1. 2010/09/18
    StratWiz
    StratWiz Inactive Thread Starter
    I have a Dell Inspiron E1705 laptop + Windows XP that worked fine untill I have updated the WiFi driver. Since then I get exclamation mark on the device and I can't turn on the WiFi.
    It had Intel(R) PRO/Wireless 3945ABG , and v11.1 driver, but was occassionally dropping rate, so I decided to update the driver to the latest 11.5. Since then I got exclamation mark on the device and was unable to turn on the WiFi anymore, and when opening its proerties it prompts a message "ADAPTER STATE NOT FOUND IN REGISTRY" and shows that device does not work properly. Installation of the driver to "found new hardware" fails says driver "the system cannot find the file specified ". I tried to rollback the driver but it did not help. I tried to reinstall the driver but no help either. Dell technician tried to repeat that and nothing changed. We can see the WiFi card in the BIOS setup.
    Dell replaced the motherboard and the WiFi card, and put Intel 4965AGN instead' but it did not help.
    I tried using WinsockXPfix that some people suggested' but it did not help. Pressing Fn+F2 or any other way of enabling the WiFi radio did not work.
    In the services.msc I see:
    Wireless Zero Configuration: | | Status Started | Startup Type: Automatic | Logs on As: Local System
    Intel ProSet/Wireless SSO Service: | | Starup: (empty) | Startup Type: Automatic | Logs on As: Local System
    Intel ProSet/Wireless Service: |Management service | Starup: (empty) | Startup Type: Automatic | Logs on As: Local System
    Intel ProSet/Wireless Registry Service: | Registry | Starup: Started | Startup Type: Automatic | Logs on As: Local System
    Intel ProSet/Wireless Event Log: | Event trace messages | Starup: Started | Startup Type: Automatic | Logs on As: Local System
    In Registry:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Ndisuio [Start]= 3
    I tried changing it to 2, 1, 0 and to reboot bu no help.
    I tried both Dell's drivers & Intel's latest drivers from Intel® Driver Update Utility for Intel® wireless adapters
    The BlueTooth can be enabled and disabled via Fn+F2, biut not the WiFi.
    Any suggestion other than reinstalling Windows XP would be appreciated.
    Thank you
    SW
  2. 2010/09/18
    Roll it back just like you updated it.
    OP has done that ....
  5. 2010/09/18
    shadow
    shadow Inactive
    I have an Inspiron 1545 and I had the same problem. When I logged in a say a message that said the drivers could not connect. I put in my driver cd that came with my computer, and I downloaded all of the wireless drivers just to be sure. When I activated it with the buttons on the top of my keyboard, it started working.
    Did you try downloading the drivers from the Resource CD (the driver CD) directly to a file it asks you to create?
  6. 2010/09/18
    Sorry saw that but had a brain fart with 5 grandkids over here running around like chickens with their heads cut off. :D
  7. 2010/09/18
    StratWiz
    I tried roll back and Safe Mode boot No Luck!
    The new wireless card's drivers are not available of the resource CD. Dell installed a newer wireless card than the one that came with the computer, i.e. it came
  8. 2010/09/18
    StratWiz
    I tried toll-back & safe mode, but no luck!
    The Dell Driver CD does not have the drivers for the newer wireless card that Dell sent me: Intel 4965AGN (the CD contains the driver for the older wireless card version I had : Intel(R) PRO/Wireless 3945ABG)
  9. 2010/09/19
    Try updating using the direct download(s) from Intel vs the Intel Driver Update Utility.
    The lastest version for XP is 12.​4.​4.​5.
  10. 2010/09/20
    StratWiz
    I tried that, but no improvement.
  11. 2010/09/22
    StratWiz
    I tried, but no luck!
    In the services I see:
    S24EventMonitor
    Intel(R) PROSet/Wireless Service
    Wireless Management Service for Intel(R) PROSet/Wireless
    C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    status: stopped
    Could not start the Intel(R) PROSet Service service on the local computer.
    Error 1075: The dependency servicedoes not exist or has been marked for deletion.
    WLANKEEPER
    Intel(R) PROSet/Wireless SSO Service
    Provides Single Sign On (SSO) functionality.
    C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
    Dependencies:
    Depends on the following:
    Intel(R) PROSet/Wireless Event Log (Started)
    Remote Procedure Call (RPC) (Started)
    Intel(R) PROSet/Wireless Service (not running)
    status: stopped
    Could not start the Intel(R) PROSet SSO service on the local computer.
    Error 1068: The dependency service or group failed to start.
