Resolved AD replication problems.
Discussion in 'Windows Server System' started by 3zzi32008, 2012/03/13.
  1. 2012/03/13
    3zzi32008
    3zzi32008 Inactive Thread Starter
    Having problems replicating between 2 DCs. Just getting into server support so this is all pretty new to me so excuse me if I sound silly at any point but really want to resolve this problem. To note, this is an inherited set-up.
    DC1 (oxin-ic-cic-01.oxin-ic.co.uk), which is server 2003 and is the schema master, domain naming master, RID, PDC and infrastructure master. Also the DNS server.
    DC2 (ic-cic-ts-01.oxin-ic.co.uk) also server 2003 uses DC1 as DNS so just has active directory installed. Also has Terminal services installed but not set-up or in use, just has the role installed.
    DC3 (oxin-sp-01) server 2008 standard, is a sharepoint server. DC3 and DC2 replicate to one another OK, but DC1 the FSMO master does not replicate with anything.
    DC1 and DC2 are not replicated, or accepting a “replicate now” command. When I click “replicate now” on either I get the same error message.
    From DC2 “The following error occurred during the attempt to synchronize naming context oxin-ic.co.uk from domain controller OXIN-IC-CIC-01 to domain controller IC-CIC-TS-01:
    The naming context is in the process of being removed or is not replicated from the specified server.
    This operation will not continue.”
    And doing the same from DC1 I get the same message. The system log has a lot of kerberos erros in it of the following.
    The kerberos client received a KRB_AP_ERR_MODIFIED error from the server host/oxin-ic-cic-01.oxin-ic.co.uk. The target name used was DNS/oxin-ic-cic-01.oxin-ic.co.uk. This indicates that the password used to encrypt the kerberos service ticket is different than that on the target server. Commonly, this is due to identically named machine accounts in the target realm (OXIN-IC.CO.UK), and the client realm. Please contact your system administrator.
    Dcdiag from DC1:
    C:\Program Files\Support Tools>dcdiag
    Domain Controller Diagnosis
    Performing initial setup:
    Done gathering initial info.
    Doing initial required tests
    Testing server: Default-First-Site-Name\OXIN-IC-CIC-01
    Starting test: Connectivity
    ......................... OXIN-IC-CIC-01 passed test Connectivity
    Doing primary tests
    Starting test: Replications
    [Replications Check,OXIN-IC-CIC-01] A recent replication attempt failed
    From OXIN-SP-01 to OXIN-IC-CIC-01
    Naming Context: DC=ForestDnsZones,DC=oxin-ic,DC=co,DC=uk
    The replication generated an error (1256):
    Win32 Error 1256
    The failure occurred at 2012-03-13 12:45:57.
    The last success occurred at 2011-06-14 08:57:20.
    825 failures have occurred since the last success.
    [OXIN-SP-01] DsBindWithSpnEx() failed with error -2146893022,
    Win32 Error -2146893022.
    Naming Context: DC=DomainDnsZones,DC=oxin-ic,DC=co,DC=uk
    Win32 Error 1256
    Naming Context: CN=Schema,CN=Configuration,DC=oxin-ic,DC=co,DC=uk
    The replication generated an error (-2146893022):
    Naming Context: CN=Configuration,DC=oxin-ic,DC=co,DC=uk
    The last success occurred at 2011-06-14 08:59:15.
    Naming Context: DC=oxin-ic,DC=co,DC=uk
    827 failures have occurred since the last success.
    REPLICATION-RECEIVED LATENCY WARNING
    OXIN-IC-CIC-01: Current time is 2012-03-13 13:27:16.
    Last replication recieved from OXIN-SP-01 at 2011-06-14 08:57:20.
    WARNING: This latency is over the Tombstone Lifetime of 180 days
    Last replication recieved from OXINSERVER-0256 at 2008-10-27 16:4
    8:10.
    8:10.
    8:10.
    Last replication recieved from IC-CIC-TS-01 at 2011-06-14 08:57:2
    0.
    Last replication recieved from OXIN-00256 at 2008-08-19 08:54:56.
    Last replication recieved from OXIN-SP-01 at 2011-06-14 08:59:18.
    8:08.
    Last replication recieved from IC-CIC-TS-01 at 2011-06-14 08:59:3
    3.
    8:10.
    0.
    Last replication recieved from OXIN-00256 at 2008-08-19 09:01:34.
    ......................... OXIN-IC-CIC-01 passed test Replications
    Starting test: NCSecDesc
    ......................... OXIN-IC-CIC-01 passed test NCSecDesc
    Starting test: NetLogons
    ......................... OXIN-IC-CIC-01 passed test NetLogons
    Starting test: Advertising
    ......................... OXIN-IC-CIC-01 passed test Advertising
    Starting test: KnowsOfRoleHolders
    ......................... OXIN-IC-CIC-01 passed test KnowsOfRoleHolders
    Starting test: RidManager
    ......................... OXIN-IC-CIC-01 passed test RidManager
    Starting test: MachineAccount
    ......................... OXIN-IC-CIC-01 passed test MachineAccount
    Starting test: Services
    ......................... OXIN-IC-CIC-01 passed test Services
    Starting test: ObjectsReplicated
    ......................... OXIN-IC-CIC-01 passed test ObjectsReplicated
    Starting test: frssysvol
    ......................... OXIN-IC-CIC-01 passed test frssysvol
    Starting test: frsevent
    There are warning or error events within the last 24 hours after the
    SYSVOL has been shared. Failing SYSVOL replication problems may cause
    Group Policy problems.
    ......................... OXIN-IC-CIC-01 failed test frsevent
    Starting test: kccevent
    An Warning Event occured. EventID: 0x80000785
    Time Generated: 03/13/2012 13:18:49
    Event String: The attempt to establish a replication link for
    Time Generated: 03/13/2012 13:18:51
    ......................... OXIN-IC-CIC-01 failed test kccevent
    Starting test: systemlog
    An Error Event occured. EventID: 0x40000004
    Time Generated: 03/13/2012 12:30:53
    Event String: The kerberos client received a
    Time Generated: 03/13/2012 12:45:57
    Time Generated: 03/13/2012 13:00:16
    Time Generated: 03/13/2012 13:25:54
    Time Generated: 03/13/2012 13:27:17
    ......................... OXIN-IC-CIC-01 failed test systemlog
    Starting test: VerifyReferences
    ......................... OXIN-IC-CIC-01 passed test VerifyReferences
    Running partition tests on : ForestDnsZones
    Starting test: CrossRefValidation
    ......................... ForestDnsZones passed test CrossRefValidation
    Starting test: CheckSDRefDom
    ......................... ForestDnsZones passed test CheckSDRefDom
    Running partition tests on : DomainDnsZones
    ......................... DomainDnsZones passed test CrossRefValidation
    ......................... DomainDnsZones passed test CheckSDRefDom
    Running partition tests on : Schema
    ......................... Schema passed test CrossRefValidation
    ......................... Schema passed test CheckSDRefDom
    Running partition tests on : Configuration
    ......................... Configuration passed test CrossRefValidation
    ......................... Configuration passed test CheckSDRefDom
    Running partition tests on : oxin-ic
    ......................... oxin-ic passed test CrossRefValidation
    ......................... oxin-ic passed test CheckSDRefDom
    Running enterprise tests on : oxin-ic.co.uk
    Starting test: Intersite
    ......................... oxin-ic.co.uk passed test Intersite
    Starting test: FsmoCheck
    ......................... oxin-ic.co.uk passed test FsmoCheck
    So it is failing on some of the primary tests.
    Dcdiag from DC2
    Microsoft Windows [Version 5.2.3790]
    (C) Copyright 1985-2003 Microsoft Corp.
    C:\Documents and Settings\administrator>dcdiag
    Testing server: Default-First-Site-Name\IC-CIC-TS-01
    ......................... IC-CIC-TS-01 passed test Connectivity
    Doing primary tests
    IC-CIC-TS-01: Current time is 2012-03-13 13:32:35.
    8:10.
    Last replication recieved from OXIN-IC-CIC-01 at 2012-02-06 20:24
    :05.
    8:08.
    :05.
    8:10.
    :05.
    ......................... IC-CIC-TS-01 passed test Replications
    ......................... IC-CIC-TS-01 passed test NCSecDesc
    ......................... IC-CIC-TS-01 passed test NetLogons
    Warning: IC-CIC-TS-01 is not advertising as a time server.
    ......................... IC-CIC-TS-01 failed test Advertising
    [OXIN-IC-CIC-01] DsBindWithSpnEx() failed with error -2146893022,
    Warning: OXIN-IC-CIC-01 is the Schema Owner, but is not responding to D
    S RPC Bind.
    [OXIN-IC-CIC-01] LDAP bind failed with error 8341,
    Win32 Error 8341.
    Warning: OXIN-IC-CIC-01 is the Schema Owner, but is not responding to L
    DAP Bind.
    Warning: OXIN-IC-CIC-01 is the Domain Owner, but is not responding to D
    S RPC Bind.
    Warning: OXIN-IC-CIC-01 is the Domain Owner, but is not responding to L
    DAP Bind.
    Warning: OXIN-IC-CIC-01 is the PDC Owner, but is not responding to DS R
    PC Bind.
    Warning: OXIN-IC-CIC-01 is the PDC Owner, but is not responding to LDAP
    Bind.
    Warning: OXIN-IC-CIC-01 is the Rid Owner, but is not responding to DS R
    PC Bind.
    Warning: OXIN-IC-CIC-01 is the Rid Owner, but is not responding to LDAP
    Bind.
    Warning: OXIN-IC-CIC-01 is the Infrastructure Update Owner, but is not
    responding to DS RPC Bind.
    responding to LDAP Bind.
    ......................... IC-CIC-TS-01 failed test KnowsOfRoleHolders
    ......................... IC-CIC-TS-01 failed test RidManager
    * The current DC is not in the domain controller's OU
    ......................... IC-CIC-TS-01 failed test MachineAccount
    ......................... IC-CIC-TS-01 passed test Services
    ......................... IC-CIC-TS-01 passed test ObjectsReplicated
    ......................... IC-CIC-TS-01 passed test frssysvol
    ......................... IC-CIC-TS-01 failed test frsevent
    Time Generated: 03/13/2012 13:18:42
    Time Generated: 03/13/2012 13:18:44
    ......................... IC-CIC-TS-01 failed test kccevent
    Time Generated: 03/13/2012 12:46:29
    An Error Event occured. EventID: 0xC25A001D
    Time Generated: 03/13/2012 12:50:15
    (Event String could not be retrieved)
    Time Generated: 03/13/2012 13:09:00
    Time Generated: 03/13/2012 13:15:05
    Time Generated: 03/13/2012 13:15:30
    Time Generated: 03/13/2012 13:19:19
    Time Generated: 03/13/2012 13:27:44
    Time Generated: 03/13/2012 13:32:36
    ......................... IC-CIC-TS-01 failed test systemlog
    ......................... IC-CIC-TS-01 passed test VerifyReferences
    I also ran dcdiag /test:dns /v on DC1 because Im not sure if it is something to do with DNS, here are the results.
    C:\Program Files\Support Tools>dcdiag /test:dns /v
    * Verifying that the local machine oxin-ic-cic-01, is a DC.
    * Connecting to directory service on server oxin-ic-cic-01.
    * Collecting site info.
    * Identifying all servers.
    * Identifying all NC cross-refs.
    * Found 5 DC(s). Testing 1 of them.
    * Active Directory LDAP Services Check
    * Active Directory RPC Services Check
    Doing primary tests
    Test omitted by user request: Replications
    Test omitted by user request: Topology
    Test omitted by user request: CutoffServers
    Test omitted by user request: NCSecDesc
    Test omitted by user request: NetLogons
    Test omitted by user request: Advertising
    Test omitted by user request: KnowsOfRoleHolders
    Test omitted by user request: RidManager
    Test omitted by user request: MachineAccount
    Test omitted by user request: Services
    Test omitted by user request: OutboundSecureChannels
    Test omitted by user request: ObjectsReplicated
    Test omitted by user request: frssysvol
    Test omitted by user request: frsevent
    Test omitted by user request: kccevent
    Test omitted by user request: systemlog
    Test omitted by user request: VerifyReplicas
    Test omitted by user request: VerifyReferences
    Test omitted by user request: VerifyEnterpriseReferences
    Test omitted by user request: CheckSecurityError
    DNS Tests are running and not hung. Please wait a few minutes...
    Test omitted by user request: CrossRefValidation
    Test omitted by user request: CheckSDRefDom
    Test omitted by user request: Intersite
    Test omitted by user request: FsmoCheck
    Starting test: DNS
    Test results for domain controllers:
    DC: oxin-ic-cic-01.oxin-ic.co.uk
    Domain: oxin-ic.co.uk
    TEST: Authentication (Auth)
    Authentication test: Successfully completed
    TEST: Basic (Basc)
    Microsoft(R) Windows(R) Server 2003, Standard Edition (Servic
    e Pack level: 2.0) is supported
    NETLOGON service is running
    kdc service is running
    DNSCACHE service is running
    DNS service is running
    DC is a DNS server
    Network adapters information:
    Adapter [00000008] Realtek RTL8169/8110 Family Gigabit Etherne
    t NIC:
    MAC address is 00:1D:7D:AA:D4:DE
    IP address is static
    IP address: 192.168.25.211
    DNS servers:
    192.168.25.211 (oxin-ic-cic-01.oxin-ic.co.uk.) [Valid]
    The A record for this DC was found
    The SOA record for the Active Directory zone was found
    The Active Directory zone on this DC/DNS server was found (pri
    mary)
    Root zone on this DC/DNS server was not found
    TEST: Forwarders/Root hints (Forw)
    Recursion is enabled
    Forwarders Information:
    195.72.164.155 (<name unavailable>) [Valid]
    195.72.171.39 (<name unavailable>) [Valid]
    TEST: Delegations (Del)
    Delegation information for the zone: oxin-ic.co.uk.
    Delegated domain name: _msdcs.oxin-ic.co.uk.
    DNS server: oxin-ic-cic-01.oxin-ic.co.uk. IP:192.168.25.
    211 [Valid]
    TEST: Dynamic update (Dyn)
    Dynamic update is enabled on the zone oxin-ic.co.uk.
    Test record _dcdiag_test_record added successfully in zone oxi
    n-ic.co.uk.
    Test record _dcdiag_test_record deleted successfully in zone o
    xin-ic.co.uk.
    TEST: Records registration (RReg)
    Network Adapter [00000008] Realtek RTL8169/8110 Family Gigabit
    Ethernet NIC:
    Matching A record found at DNS server 192.168.25.211:
    Matching CNAME record found at DNS server 192.168.25.211:
    d2f3d164-fd7d-41dd-87f2-466123c46168._msdcs.oxin-ic.co.uk
    Matching DC SRV record found at DNS server 192.168.25.211:
    _ldap._tcp.dc._msdcs.oxin-ic.co.uk
    Matching GC SRV record found at DNS server 192.168.25.211:
    _ldap._tcp.gc._msdcs.oxin-ic.co.uk
    Matching PDC SRV record found at DNS server 192.168.25.211:
    _ldap._tcp.pdc._msdcs.oxin-ic.co.uk
    Summary of test results for DNS servers used by the above domain contro
    llers:
    DNS server: 192.168.25.211 (oxin-ic-cic-01.oxin-ic.co.uk.)
    All tests passed on this DNS server
    This is a valid DNS server
    Name resolution is funtional. _ldap._tcp SRV record for the fores
    t root domain is registered
    Delegation to the domain _msdcs.oxin-ic.co.uk. is operational
    DNS server: 195.72.164.155 (<name unavailable>)
    DNS server: 195.72.171.39 (<name unavailable>)
    Summary of DNS test results:
    Auth Basc Forw Del Dyn RReg Ext
    ________________________________________________________________
    oxin-ic-cic-01 PASS PASS PASS PASS PASS PASS n/a
    ......................... oxin-ic.co.uk passed test DNS
    Im really tearing my hair out here, with no sense of direction in terms of what I should be looking from now and I’m hoping someone can direct me from the diagnostic results above. Its seems that DC2 and DC3 are more up to date than DC1 as well, as there are a couple of machines I added to the Domain a couple of months ago and they are not showing in AD Users and computers on DC1 but are on DC2 and DC3.
    Hope this thread isn't overkill but just wanted to provide as much info as possible to start with. Hoping I can crack this with some help from you guys. 
    Thanks in advance.
    Ezzie
  2. 2012/03/19
    MichaelF
    MichaelF Inactive
    3zzi32008
    Thank you, I had already resolved this issue before reading your response. I seized all roles onto DC2, dcpromo /forceremoval on DC1 and then re-installed AD and all is working again now.
    thanks.
  5. 2012/03/23
  6. 2012/04/16
    3zzi32008
    Sorry about this. All done now.
