ActiveX Controls where are they keep ?
Discussion in 'Windows XP' started by Gladd8tor, 2005/08/06.
  1. 2005/08/06
    Gladd8tor
    Gladd8tor Inactive Thread Starter
    Hi ... Where does all the ActiveX Controls files get keep on the computer ? Thanks
    PS: I have Windows xp pro version sp2
  2. 2005/08/06
    The Active X controls are registry entries.
    What do you need to do?
    Welshjim
    Welshjim Inactive
    Gladd8tor--C:\WINDOWS\Downloaded Program Files on my PC.
    Another way to access is IE Tools|Internet Options|General tab|Settings|View Objects.
  5. 2005/08/06
    Gladd8tor
    Hi ... Well I don't want to get into a long story as to how or who but I have one activex which is from a website that I don't care to visit and it got install on my computer , I would like to remove it , Now from Welshjim post I did find what I believe is the one but , What Newt just mention I didn't removed if its hidden in the registry , So where in the registry do they get stored ? Also because I do use IE6 browser I'm curious as to the " Manage Add-ons " area if something is listed in browser section and you select it to be disable that that mean its been removed ? Thanks
  6. 2005/08/07
    If you have established through Jim's route to View Objects the ActiveX download in question via > highlight object > right click > properties .... just delete it. Should you visit that site again the control will be downloaded again. Deletion should remove any relevant registry entries too.
    Each and everyone of those controls can be deleted - they will be downloaded again when you revisit sites which require them. In fact the Disk Cleanup Wizard marks them for deletion by default.
    However, this is unwise as the ActiveX controls for Windows Update and Windows Validation are stored here.
  7. 2005/08/07
    Gladd8tor
    Hi ... Thanks for your input but, Those are not the ones I would like to remove from the Manage add-ons , So once you disable any listed ones in the manage add-ons area , Are they then removed , Or are they still stored somewhere ? Thanks
  8. 2005/08/07
    I was making the point that Disk Cleanup - which deletes ALL the Downloaded Program files by default should be avoided as some/most of these files are required.
    I would not think so as you can re-enable them at a later date, if required.
    Have you searched the Registry for a key word associated with that particular ActiveX control?
  9. 2005/08/07
    Nontechguy
    Nontechguy Inactive
    Could this one be deleted its from my cousin the trouble maker :rolleyes:
  10. 2005/08/07
    Gladd8tor
    Hi ... I'm using jv16 Power Tools ( Latest version ) It show about 20 entery of it , I was just wandering if I delete them would that remove them from the Manage add-ons area ? Now it has nothing to do with windows , its just from a website that I wish that would of never gotten on my computer in the first place ...
    TIA
  12. 2005/08/07
    charlesvar
    charlesvar Inactive Alumni
    Hello Gladd8tor,
    Yes, if you removed them, but you write "them ", are you removing more than just what you want to remove?
    Make sure that jvPT's restore option is set and that you make a manual System Restore point and have confidence that least at one works.
    Regards - Charles
  13. 2005/08/07
    Gladd8tor
    Ok what I have done was I try one like Charlesvar suggested and it seem to of work , so I then restored back, when back again to use jv16 but , this time I use the back up feature jv16 has and selected to remove all entery , Now though I am curious in the Manage add-ons area , what does this mean when you notice a entery like this below ??
    Yahoo! Audio Conferencing ( Not verified ) yahoo! Inc, Enabled ActiveX Control yacscom.dll
    The Not Verified is what i'm concern about , Is this just a missing dll file ?
    Again TIA ....
  14. 2005/08/07
    charlesvar
    No, it doesn't mean a missing file, it's a matter of windows not recognizing it officially the way a Symantec entry would be, meaning it's not approved or disapproved of.
    Regards - Charles
  15. 2005/08/07
    Gladd8tor
    Okay cool :cool: I and my cousin thank all the members in this forum
