A Strange Question
Discussion in 'PC Hardware' started by bluenose12, 2004/07/11.
  1. 2004/07/11
    bluenose12
    bluenose12 Inactive Thread Starter
    I just put a second hard drive in my AMD XP Athlon 2000 PC.I've had it in for a couple of days now and it's running fine.The strange question is......Every so often I hear a quiet sound coming from my computer case.The only way I can describe the sound is it's like a squeaky hinge on a door.It only lasts for a second at most and I hear it maybe once every 20 mins. or so.Does anyone have any idea what it could be?...It has only done it since I put in the new hard drive which is a Hitachi 80 GB 7200 drive.
  2. 2004/07/11
    Christer
    Christer Geek Member Staff
    The squeaky hinge sound or the cat meow sound is a hallmark of the 7K250. They all had it until a recent firmware upgrade (as of june I think).
    Go get a case of beer or lots of coffee and enjoy the reading in this thread at StorageReview!
    Christer
    bluenose12
    Thanks for your reply..........I thought I was going nuts. :(
    It seems then that this noise is normal for this drive and it is not a fault??
    Am I right?
  5. 2004/07/12
    Christer
    Yup, it's normal and the time to start worrying is when it ceases to meow ...... ;) ...... !
    It is possible to update the firmware in "older" drives to the new "meow-less" version. The update is not officially published on Hitachi's home page but get in contact with them and You'll get it.
    The sound doesn't bother me personally and it is kind of reassuring to hear that it's still alive ...... :cool: ...... and I always wanted a cat without the need for a litter box!
    Christer
  6. 2004/07/12
    bluenose12
    I have a cat and don't have a litter tray.....he goes out when he needs the loo. :D
    I installed the Firmware update and no squeal from the drive so far. :)
    Thanks for your help. :)
  7. 2004/07/12
    Christer
    You're welcome ...... :) ...... !
    Christer
