Resolved A Problem with Sleep Mode
Discussion in 'Windows 7' started by VaCcAr0, 2010/06/27.
  1. 2010/06/27
    VaCcAr0
    VaCcAr0 Well-Known Member Thread Starter
    Every time I wake my computer up from sleep mode I get a blue screen and it says KERNEL_DATA_INPAGE_ERROR
    I don't know why this is happening or what I can do at this point to resolve it. I already tried error checking the hard drive and I always run my up-to-date webroot antivirus software but that didn't resolve the problem. Any other suggestions on what I should do? I would very much appreciate all the help I can get for this one.
  2. 2010/06/27
    I would check your memory .....
    Orb > type in the Search Box 'Memory'and in the search results click on Memory Diagnostic', noting .....
    The only satisfactory way of testing RAM is to test the installed RAM in various configurations. If you have a single module swap it around the slots. If you have a pair of modules run each one singly, swapping between slots; then run them in pairs swapping between pairs of slots. If you have 2 sets of matched modules do not get them mixed up.
    VaCcAr0
    Thanks. I ran memory diagnostic and it said no problem was detected. When I tried sleep mode again I did not get the blue screen so hopefully whatever caused it is gone now.
