98 won't connect to network
Discussion in 'Networking (Hardware & Software)' started by jseabolt, 2008/05/25.
  1. 2008/05/25
    jseabolt
    jseabolt Inactive Thread Starter
    I'm running Windows 98 first edition and when I click on "Entire Network" I get an error message telling me I cannot connect to the network.
    I can connect to the internet through a router so that's not the problem.
    I think it's because I need to to set up my network manually (where XP does it for you) but I can't remember how to do it. It's been about three years since I've fooled with 98.
  2. 2008/05/25
    jseabolt
    Fixed it. Well sort of.
    I had to manually look for my other computers. Some are listed under "MSHOME" and some under "WORKGROUPS ".
    They still don't show up under Network Neighborhood for whatever reason.
    I just made desktop shortcuts and moved them to a folder on my desktop.
  5. 2008/06/01
    Change all comps to same workgroup.
  6. 2008/06/01
    visionof
    visionof Inactive
    On a windows xp machine go into the tc/ip settings of the network card used
    Basically copy those into the same settings in the windows 98 machine
    The network name has to be the same on the machine to enter the network
    In windows 2000 / XP ifs MShome in Windows 98 its something else
    What a wise way to set up your networking for people to have problems
    Change the network name on the Windows 98 machine to MShome or whatever it is named now
