Resolved 750GB external HDD problem
Discussion in 'PC Hardware' started by kieer06, 2013/04/23.
  1. 2013/04/23
    kieer06
    kieer06 Inactive Thread Starter
    ,What should i do with my external HDD, when im going to format it, it says that format cannot be done. what is the problem of my hdd?
    :confused::confused::confused:
  2. 2013/04/23
    Hi kieer06, We will need more info on your System please.
    What OS are you running?
    If you are running W7, I found this procedure: Format Hard Drives in W7.
    http://www.ehow.com/how_8120853_format-hard-drives-windows-7.html
    Please take the time to fill in your System Details > UserCP > and scroll to the bottom and SAVE before exit. Neil.
    kieer06 likes this.
    SpywareDr
  5. 2013/04/25
    kieer06
    #retiredlearner
    hello! good day, im running winXp Sp3, Thanks..
    #SpywareDr
    S/N 70SKS02BS LA2 EC.@
    hello! My HDD brand is TOSHIBA MK7559GSXP
    almost 3 years old sir..
    HELP ME PLEASE thanks
  6. 2013/04/26
    Is your external drive recognized when you Right click My Computer > Open > Should have Alpha letter showing > Right click on Local Disc X (Alpha) > options pane opens > Format > Format Local Disc ???
    What happens? Neil.
    kieer06 likes this.
  7. 2013/04/26
    SpywareDr
    What I would try first is to remove the Toshiba MK7559GSXP hard drive from the external enclosure, connect it directly to a SATA connector on a Desktop PC motherboard then power-up and see if the drive is recognized in the BIOS. If not, the hard drive may be dead. :(
    kieer06 likes this.
  8. 2013/04/26
    kieer06
    Yes its. recognize. my problem is when im formatting my hdd its not done successfully i read a article using Windows98SE mSdos prompt. formatting method. but i go here to ask for another solutions. thanks guys i really appreciate.
  9. 2013/04/26
    SpywareDr
    AFAIK, hard drives using the new Advanced Format, (like your Toshiba), should be partitioned and/or formatted under Windows 7/Vista for later use on Windows XP.
    kieer06 likes this.
  10. 2013/04/26
    Doc, I have a query about the size of the HDD (750GB) and the relationship to CPU? Neil.
    kieer06 likes this.
  11. 2013/04/27
    I highly doubt a 3 year old, 750 GB hard drive would use Advanced Format...
    kieer06 likes this.
  12. 2013/04/27
    SpywareDr
  13. 2013/04/27
    kieer06
    woa.! thanks for the helps. guys Godbless... i try wat u recommended 2 me thanks a lot guys...
  14. 2013/04/27
    kieer06
    hello! guys i'm not familiar with AF , do i need to use a Software or win7 by default haved the AF? sorry , ^^, thanks for the HELP! i appreciate it..
  15. 2013/04/27
    JRBreneman
    JRBreneman Inactive
    kieer06 likes this.
  16. 2013/04/28
    kieer06
    kieer06 likes this.
  18. 2013/04/28
    You don't need anything for Windows Vista or later.
    Now, I think you should check out the drive using the manufacturer's disk diagnostics:
    Fujitsu / Toshiba
    kieer06 likes this.
  19. 2013/04/28
    SpywareDr
  20. 2013/06/02
    kieer06
    hello! gooday 2 everyone , im sorry for the late response. ive been busy for the last 2 weeks. im doing all the suggestions you made and i all appreciate it. thanks for the help guys.
  21. 2013/06/07
    kieer06
    toshiba / fujitsu manufacturer's disk diagnostics , is not working on my HDD. t.t what should i do now Sir SpywareDr, Arie, Retiredlearner, JRBreneman :/
