4.7 to 4.79 Upgrade - Issues and Concerns?
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Fenris, 2002/12/16.
  1. 2002/12/16
    Fenris
    Fenris Inactive Thread Starter
    A computer at the house has 4.7 on the system, and the owner of that machine wants 4.79 installed per the instructions of a bank or something, in order to get into the secure website for banking purposes or something.
    Anyways, I've downloaded 4.79, and am waiting to install it. However:
    -Do I uninstall 4.7 first?
    -If so, what do I save in order to preserve bookmarks and mail?
    -What should I watch out for, be cautious with, or be mindful of?
    Any other advice would be appreciated. Thanks!
  2. 2002/12/17
    tranquilo
    tranquilo Inactive
    This is not required, though sometimes it is helpful to uninstall first.
    Back up the user profile... I believe the default is:
    c:\program files\netscape\users
    hmm.. perhaps Ramona will chime in here, as it's been quite some time since I have used Netscape 4.x.
    tranquilo
    Ramona
    Ramona Geek Member Alumni
    Hi Fenris,
    I would suggest that you do a "Clean Install" of 4.79, which means to uninstall 4.7 first. By removing and then reinstalling the software, you replace all of its files, not just the newest ones.
    I have "Clean" Install guidelines which will give you step by step instructions. If you have more questions, post back.
    Ramona :D
