2 partitions of the same letter (C)
Discussion in 'Windows XP' started by joedotm, 2010/03/03.
  1. 2010/03/03
    joedotm
    joedotm Inactive Thread Starter
    Dear all,
    I had to re-install Vista on a Sony Vaio but in vain; while expanding, it stops at a certain time and give me an error code; browsed the internet for a long time, yet, no solution;
    Used the F key to recover, but in vain; i get the message that drive too small to recover.
    Then I decided to install XP pro. It shows C: recovery partition (around 8GB) and I create another partition (around 175GB), yet it is named C.
    What do you think about that?
    PS. Meanwhile, XP copying files, restarting the laptop and nothing on the screen!!!
    Restarted, deleted partition, recreated partition, it took the letter C and the recovery became F. Installation in progress!!!
  2. 2010/03/04
    yet it is named C -> I bet you were in Vista when you saw that...Its normal.
    jaydeee
    jaydeee Inactive
    never encountered this...
    or may be I have to try it but just wondering how hehehe!
    thanks its wondering :)
