2 operating systems, I need to remove 1
Discussion in 'Windows XP' started by rickymorr, 2011/12/23.
  1. 2011/12/23
    rickymorr
    rickymorr Inactive Thread Starter
    I have printed off the info for removal of 1 OS, but cannot find the Windows Explorer folder that I want to remove, The PC is Dell Inspiron 9400 with XP Pro
  2. 2011/12/23
    SpywareDr
    What is the drive letter of the drive that contains the Windows folder that you want to remove?
    (Warning: You probably do NOT want to remove the Windows on drive C: because that usually contains the Windows Operating System that is currently running your computer).
    rickymorr likes this.
    rickymorr
    Ithink its D, When the pC starts up it ask you to select 1 of the 2 OS both identicle, The 1 selected is on C, Many Thanks
  5. 2011/12/23
    SpywareDr
    To delete the Windows folder on drive D:, load Windows Explorer (press [Winkey]+[E]), select drive D:, then right-click the Windows folder and select delete.
    grensam likes this.
  6. 2011/12/23
    rickymorr
    Cant get to the PC till next week now, as soon as I come back I'll try that, and Thank You for Your Time, Ricky
  7. 2011/12/23
    Before you delete anything, are you certain you have 2 separate XP operating systems installed on separate partitions on the computer? If you are sure, then tell us how and why you managed to do that?
  8. 2011/12/23
    wildfire
    wildfire Getting Old
    Perhaps best to post your BOOT.INI and let us take a look. As Tony suggested you may not have two OS's and simply editing this (with careful guidance) may be enough.
